查看: 48148|回复: 13
DS203 New Firmware, New Interface, New Style. C07 Update.
发表于 2014-8-26 15:55:02 | 显示全部楼层 |阅读模式
Posted 2013-9-13 15:23:19 Author: sagittarius
The bugs in single mode are debugged.
Display of AUTO “operate” and “stop”
Display of triggering mode
Real-time display of two measurement values
Firmware
This firmware is modified on the basis of Mater Yijian’s version.
1. New interface. Smaller font. No major change of basic operation. Choices on the top line are moved to the right. The cursor choices can still be shifted by the triangle button.
2. Display of 11 measurement values
3. Screenshot can be made by long pressing the square button
[blockquote]
I’m a newbie. My firmware is imperfect. If you guys detect any bugs, please inform me. I’ll try my best to make it better.
C07 code download  see the 7# comment
Version C06:
Removal of the bug of recapturing waveform unchanged when the time base is changed
The firmware covers the size of two apps: C06.rar (92.14 KB, 下载次数: 6113) (90.82 KB, Downloads: 193)
C05:
Saving trig mode and storage depth
New color pattern of the interface
The firmware covers the size of two apps:   C05.rar (92.03 KB, 下载次数: 5147) (90.82 KB, Downloads : 139)
C04:
Referenced after Wangluoguke’s version
Removal of the bug that when T2 is to the left of T1, the Triangle T data can not be displayed.
Removal of the bug that the difference value between T1 and T2 does not appear when it is larger than 2.14s.
Impact wave output Pul (simulating human heart pulsation cycle) is added to the signal generator.
Removal of the bug that choices on the right are directly made by the ITEM wheel cycle.
The firmware covers the size of two apps:   C04.rar (91.84 KB, 下载次数: 5081) (89.84 KB, Downloads : 128)
C03:
Small bugs are fixed such as saving the bottom items on the right and hiding the 2nd choice of CH3 and CH4.
The firmware covers the size of two apps: C03.rar (90.57 KB, 下载次数: 5002) (88.87 KB,  Downloads : 127)
Firmware source code compressed package 1: C03_code.part01.rar (1.91 MB, 下载次数: 5455) (1.86 MB,  Downloads : 210)
(The source code needs both packages to be uncompressed)
My program modification might be messy. Hope you guys could shed some lights for its improvement.
C02:
Compatible with 2M and 8M Flash. 8M Flash is not subject to the SYS versions. This firmware applies for SYS bottom of all versions.
APP1: installed at APP1’s position. Covering the size of two apps:   APP1_C02.rar (45.68 KB, 下载次数: 7686) (44.92 KB,  Downloads : 106)
APP3: installed at APP1’s position. Covering the size of two apps: APP3_C02.rar (45.68 KB, 下载次数: 7747)   (44.92 KB,  Downloads : 101)
C01:
I use 2M Flash DS203. This firmware applies for SYS bottom of all versions.
8M Flash DS203 must install SYS_1.50 before it uses this firmware to reinstall system.
This firmware covers the size of 2 apps. So I divided it into both the position of App1 and App3.
APP1: installed at APP1’s position. Covering the size of two apps: APP1_C01.rar (48.41 KB, 下载次数: 7563) (47.85 KB, Downloads : 107)
APP3: installed at APP3’s position. Covering the size of two apps: APP3_C01.rar (48.4 KB, 下载次数: 7692) (47.85 KB, Downloads : 100)
发表于 2015-1-29 16:27:14 | 显示全部楼层
Hello, can you give the source code for the last version.
Thanks
发表于 2015-1-29 17:39:36 | 显示全部楼层
v1.13
发表于 2015-1-30 06:46:17 | 显示全部楼层
Sorry,
Is not the source code for C06. (i like the interface)
i have look some change .
In the boot  you can read "Reload parameter form disk". A lite error, => "Reload parameter from disk" is a write error in the origianl source code.
for Boot on App3 the string must be chnaged to "Plus A1" to "Plus A3"
and i will translate this C07 to french for french user.
Another question you are write a c07 ?
Thanks
发表于 2015-1-30 06:51:21 | 显示全部楼层
and i forget,
In the File.c the best is change the extension of the parameter for have multi parameter with App1 and App3
in APP1 save setting make :
XXXXXXXX.PAR
XXXXXXXX.BAK
in APP3 save setting (any exemple) :
XXXXXXXX.3AR
XXXXXXXX.3AK
This is better
发表于 2015-1-30 14:33:41 | 显示全部楼层
Manu68350 发表于 2015-1-30 06:51
and i forget,
In the File.c the best is change the extension of the parameter for have multi parame ...
C07_code.rar (639.1 KB, 下载次数: 4763)
发表于 2015-3-22 22:34:11 | 显示全部楼层
Why don't I see a *C07.rar  ? I thought C07 firmware is to be found here ? (new user, sorry if I am looking at the wrong place)
发表于 2015-3-23 09:41:23 | 显示全部楼层
AKen 发表于 2015-3-22 22:34
Why don't I see a *C07.rar  ? I thought C07 firmware is to be found here ? (new user, sorry if I am  ...
发表于 2015-3-23 22:30:18 | 显示全部楼层
I were hoping for a built version, I am far out at sea with only a sliw satlink, and did not built it before, so even if my Ubuntu make tools , mostly related to amega could do it, I would not know how.
发表于 2015-5-15 01:20:35 | 显示全部楼层
[i = s] posts by gz06 in 2015-5-15 01:31 Edit
[i = s] posts by gz06 in 2015-5-15 01:30 Edit
Hi, alsmost several years I have such device and right now only I found such website. How to install C7 on ds203?
I downloaded it, but do not know how to update it?
and second:
How to move up/down yellow channel "B" position?
GMT+8, 2026-10-20 22:48 , Processed in 0.192822 second(s), 28 queries .
