查看: 17571|回复: 12
Error in update
发表于 2015-6-29 08:23:31 | 显示全部楼层 |阅读模式
I tried to upgrade the oscilloscope , but he is now presenting instability in operation. The readings are distorted and sometimes the machine hangs. The PC no longer recognizes the drive when connecting the USB port. IF anyone can help , I will be grateful!
Ps .: Sorry for the english translated by Google
发表于 2015-6-29 09:35:02 | 显示全部楼层
Your DS203 HW, SYS, APP is what version, unstable after what upgrade to version?
Do you have any testing isn't bad USB cable?
 楼主| 发表于 2015-6-29 10:19:23 | 显示全部楼层
Already tested with several USB cable , but I can never format the drive . As the other information you asked , I will check tomorrow and then return with the answers.
 楼主| 发表于 2015-7-2 08:02:44 | 显示全部楼层
The home screen shows the following information. When you are trying to save a parameter the message " Load File Fail". Thanks!
 楼主| 发表于 2015-7-2 08:05:51 | 显示全部楼层
 楼主| 发表于 2015-7-2 08:15:05 | 显示全部楼层
I am unable to attach to the image post
发表于 2015-7-2 09:26:10 | 显示全部楼层
What is your PC system?But you try format disk under Windows 7.
 楼主| 发表于 2015-7-3 05:29:42 | 显示全部楼层
I have a PC with windows xp and a notebook with Windows 8.1 , but I can not format the drive of the DS203 on both computers .
发表于 2015-7-3 09:34:42 | 显示全部楼层
gomez06 发表于 2015-7-3 05:29
I have a PC with windows xp and a notebook with Windows 8.1 , but I can not format the drive of the  ...
Normal equipment is: DFU mode cannot be formatted disk, only in the APP mode can format a disk.
Your DS203 in APP mode and DFU mode can identify disk?
If the APP mode can identify the disk but not formatted, may be the Flash chip is broken.
(DFU version number less than V3.42, connection win8.1 may be unstable, Windows 7 is no problem. Suggest that had better use usb connection)
 楼主| 发表于 2015-7-4 06:08:55 | 显示全部楼层
The two modes are recognized by the PC . You can access the DFU mode and install the update, however, the APP mode , you can not format the drive .
?dl=0
GMT+8, 2026-10-20 23:47 , Processed in 0.148902 second(s), 21 queries .
