查看: 9754|回复: 2
CSV file question
发表于 2015-2-15 20:38:13 | 显示全部楼层 |阅读模式
Cattura_326.jpg Hi , I have just bought your DS203 V2 good product everything is fine !
I made a measure of 2 pulse 1 on CHA and 2 on CHB (CH C and CH D hide) each pulse duration 10millisec ON 3 sec OFF
I saved bmp image of the plot and I saved .CSV file to plot graph on Excel  (please see attached image with excel and bmp together)
On CSV file I see track 1,2 for ChA and ChB, but I read also track 2, 3 , I suppose ChC and Ch D to hide them but I read values .Is it right?
Moreover I can not read any time value to plot graph on Excel.Maybe I miss something?
发表于 2015-8-20 16:49:21 | 显示全部楼层
Hi,
I wish I can help but I just received my DS203 1 hour ago. I am still trying to figure out which is the latest firmware upgrade and WHERE to get it, this Chinese site is more confusing than helpful? Secondly what software is available to import and display the output which I save. From the above plot you made I gather you have to make your own excel file and import the results as a CSV file. How do I know what field match which output etc etc. I am about to give up before I start, lol, however I need to earn my bread and butter with this system since I am busy tuning a patent which will make or break me. I do not have funds for a proper scope (anyway not after choosing this DS203?) and HAVE to get it working. I hope you can give me some pointers to avoid me trying to redesign the wheel here? As a matter of consolation I am fairly computer literate and promise to see how I can be of assistance to you, once I am familiar with the system. Just from looking at your data it seems that CH-c and d is your digital output, which currently shows a (CONSISTENT for both channels) logical value of 1 for C and a 0 for D which corresponds with what you have on your CH A & B. In other words the readings are correct since your TEST wave never dropped here?. Hope this helps. In your data file you should have a CSV field somewhere which you can use to extract timing, but as I said I have got no clue currently about how the structure works. Remind me to get back to you in a couple of days if I do not respond further. Regards Ben.
发表于 2015-8-21 09:53:48 | 显示全部楼层
ChC and Ch D to hide them,Just don't show on the screen, actually still at work. So you can read values.
GMT+8, 2026-10-20 23:47 , Processed in 0.161149 second(s), 24 queries .
