查看: 15063|回复: 2
FPGA Configration Err!
发表于 2014-10-15 01:12:17 | 显示全部楼层 |阅读模式
Sorry for my english.
I bought a DS203 and it was showing:
Hardware Ver 2.81
DS203 Mini DSO SYS Ver 1.62
DS203 Mini DSO APP (PLUS A1) Ver 1.13
I wanted to change firmware on it.  I held down the >|| button, turned the DS203 on, connected it to Windows, saw the "DFU V3_40_C" drive, and copied GABOUI_1.hex from https://github.com/gabonator/DS203/tree/master/Bin. I restarted the DS203 but now I get the message "FPGA Configration Err!". I have tried copying other .hex files, but I keep getting the same message on restart.
What files can I copy to my DS203 to make it original again? Thanks in advance.
发表于 2014-10-15 14:48:03 | 显示全部楼层
FPGA_281.ADR (12 Bytes, 下载次数: 5271)
281_FPGA.bin (131.93 KB, 下载次数: 5132)
You'll have to write the FPGA program, first write FPGA_281. ADR, then write FPGA_281. BIN
 楼主| 发表于 2014-10-17 03:50:16 | 显示全部楼层
Thank you! Those files helped.
If it helps anyone, that message is misspelled and should say "configUration".  Thanks again.
GMT+8, 2026-10-24 14:02 , Processed in 0.168033 second(s), 24 queries .
