查看: 14525|回复: 0
I found a dope DS203 App
发表于 2014-8-26 16:19:33 | 显示全部楼层 |阅读模式
Posted 2012-7-3 16:31:36 Author: brtwfxh
When I was surfing around overseas websites, I found a DS203 app able to include other apps into the inbuilt USB disk. 2M’s capacity accommodates 20~40 apps. And these apps are run by the decision on the graphical interface.
Let me show you some pics.
Here’s the intro of the app: http://essentialscrap.com/dsoquad/pawn.html
App download: https://github.com/PetteriAimonen/QuadPawn
Youtube into (you need a proxy if you are in Chinese mainland): http://www.youtube.com/watch?v=WwzGsEINN3o
For mainland Chinese, I make this apps local. It there’s a copyright problem, I need the a favor from the forum manager to delete this.
Instruction: there should be six flies after it is uncompressed. Copy the pawn_003.hex into DS203 in the mode of DFU and copy the rest 5 amx files into DS203 in the regular USB disk mode. At last, long press the triangle button to start your device.
GMT+8, 2026-10-24 14:02 , Processed in 0.164077 second(s), 24 queries .
