查看: 16657|回复: 0
DS203 simple instructions
发表于 2014-7-30 14:50:10 | 显示全部楼层 |阅读模式
Posted 2012-5-11 10:58:49  Author: emaliy
1. In the operating state, press "> ▎" key to select "Run" / "pause" mode
2. In working condition, the cursor is positioned "CH_A" or "CH_B" when long press "■" key to enter the calibration status
3. In working condition, press the "●" key function to "save the current setup parameters"  »
4. In working condition, so dial "- ... +" button to select a different "Index" option
5. In working condition, press down. "- ... +" Key, select a different "Detail" option
6. In working condition, so dial "<...>" button, choose a different "Item" option
7. In working condition, press down on the "<...>" key to select different "Waveform Display Settings" "Waveform Measurement Setup" option two categories
8. In working condition, the cursor is positioned "SAVE" or "LOAD", press "▲" key, perform file operations
9. In the calibration status, the reference voltage meter parallel input of the oscilloscope probe
10. In the calibration status, the first line of the screen displays the calibration message
11. In the calibration status, dial around "- ... +" button, adjust the calibration readings (of reference voltage meter reading)
12. In the calibration status, so dial "<...>" button to select a different calibration stalls
13. In the calibration status, press down on the "<...>" key to select different calibration parameter options
14. In the calibration state, the cursor is located in the bottom row, left dial "- ... +" button to choose a different way to exit calibration
15. In the calibration status, the cursor is located in the bottom line, press "■" button to exit the calibration status, return to work status
16. In operation, the color "TRIGG" and "YPOS" items in column two, which means that the corresponding channel "A, B, C, D"
17. In the operating state, all "measurement parameters" field of the color represents the corresponding channel "A, B, C, D, common"
18. In working condition, "BL" column, which means that the screen backlight brightness adjustment dial with around "- ... +" button to adjust
19. In working condition, "Vol" column indicates the buzzer volume adjustment dial with around "- ... +" button to adjust
20. "TRIGG" mode column, "> Vt" and "<Vt" said measured signal is greater than or less than the trigger level for that channel Vt values
21. "TRIGG" mode column, "> TH" and "<TH" said trigger signal high pulse width is greater than or less than the cursor ⊿ T = T1-T2 values
22. "TRIGG" mode column, "> TL" and "<TL" said trigger signal low pulse width is greater than or less than the cursor ⊿ T = T1-T2 values
23. In working condition, if sustained 600 seconds (10 minutes) no button, the system automatically enters power-saving state, the green indicator light
24. In power-saving state, press any key, the system will automatically return to work status, the green light is off
25. In any state, the red indicator light, said inside the battery state of charge, and vice versa, or that the battery is fully discharged state
Posted 2012-05-16 21:24:40 Author: randy
I, as a beginner, suggest the Floor Host write some good introductory post for the beginners. Thanks!
Posted 2012-06-04 20:59:23  Author: zrb5688
Wondering if you would write more detailed explaination, because I don’t know how to use some functions.
Posted 2012:06:04 22:01:32 Author: sbmtv
GMT+8, 2026-10-24 14:03 , Processed in 0.151757 second(s), 21 queries .
