查看: 5|回复: 0
TS1M Power Tool Battery Base (Cordless Soldering Mod)
发表于 7 小时前 | 显示全部楼层 |阅读模式
Description:
Turn your MINIWARE TS1M mini soldering station into a completely cordless tool! This 3D-printable adapter allows you to power your TS1M using Makita, DeWalt, or Milwaukee 18V/20V/24V power tool batteries.
Features:
Multi-Battery Compatibility: Includes mounting slots for Makita, DeWalt, and Milwaukee battery interfaces.
Seamless Integration: Securely holds the TS1M on top of the battery.
Easy Build: A detailed BOM (Bill of Materials) is provided. You can easily purchase the required metal battery terminals and DC plugs online.
Print & Assembly Recommendations:
Material: Print with PETG, ABS, or ASA for better heat resistance and structural strength
Hardware: Please refer to the attached BOM list for the required metal contacts and wiring.
⚠️ Safety Note: Double-check the polarity (+/-) and insulate your connections. Power tool batteries can deliver massive current—short circuits are extremely dangerous! TS1M supports 12-28V input, perfectly matching standard 18V/20V power tool batteries.
迷你焊台电池座3D文件.zip
369.31 KB, 下载次数: 0
BOM EN.pdf
302.99 KB, 下载次数: 0
how to install.pdf
1.53 MB, 下载次数: 0
GMT+8, 2026-11-18 18:11 , Processed in 0.157632 second(s), 24 queries .
