查看: 298|回复: 0
[Firmware update] Material Download For AirGo 140 Hot Air Gun
发表于 2026-9-11 16:27:24 | 显示全部楼层 |阅读模式
2026.09.24:
AirGo140 Hot Air Gun APP V1.30:https://forum.minidso.com/forumdownload/AirGo140APPV130.zip
-Fixed compatibility issues with some chargers under 110V power supply.
-Fixed the whining noise issue at level 3.
-Fixed a potential motor startup timeout issue on some motors.
-Added a sleep memory function for Cool mode.
-Added a Left/Right Hand mode setting.
-Fixed the issue where a low voltage warning appeared when starting heating via the APP under DC power supply.
2026.09.11:
AirGo140 Hot Air Gun UserUser Manaul CN EN RU V1.0: https://forum.minidso.com/forumdownload/AirGo140 User Manaul.CN.EN.DE.RU.V1.0.pdf
GMT+8, 2026-10-29 22:58 , Processed in 0.155826 second(s), 21 queries .
