查看: 787|回复: 2
MDP-906 does not remember the Input current limit
发表于 2026-1-29 21:32:24 | 显示全部楼层 |阅读模式
After switching off and on, Input current limit always set to 3A
发表于 2026-1-30 09:10:59 | 显示全部楼层
The input current limit of 3A is the default setting. For safety reasons, it needs to be manually adjusted each time it is used.
 楼主| 发表于 2026-8-27 03:42:49 | 显示全部楼层
But that's nonsense. Make the setting persist.
All devices of this kind have this.
GMT+8, 2026-11-8 04:27 , Processed in 0.150200 second(s), 21 queries .
