查看: 1810|回复: 1
[Troubleshooting] [ES15S] Intelligent control (Motion Control) isn't working
发表于 2025-10-21 03:50:31 | 显示全部楼层 |阅读模式
The screwdriver's intelligent control (Motion Control) isn't working. I've tried everything possible: resetting it to factory settings, updating the firmware to version 1.60, adjusting all possible sensitivity settings... nothing helps.
I also calibrated it (version screen -> run button press -> short , long , long , short , short.).
Any ideas what the reason might be?
Model: ES15S
config.txt:
Speed=2                         #0-220rpm,1-360rpm,2-470rpm
Sensitivity=2             #0-Low,1-Middle,2-High
Torque=3                       #1-5
Impact=0                       #0-OFF,1-ON
Retreat=0                     #0-OFF,1-ON
Light=1                         #0-OFF,1-ON,2-Delay
BackLight=3                 #1-5
Beep=1                           #0-OFF,1-ON
Language=1                   #0-Chinese,1-English
Battery_m=0                 #0-OFF,1-ON
Mode=0                           #0-AUTO,1-Positive,2-Rollback,3-Safe
发表于 2025-10-21 09:41:04 | 显示全部楼层
Please email to service@morningtools.com , we will help you.
GMT+8, 2026-11-4 06:34 , Processed in 0.157348 second(s), 21 queries .
