查看: 1351|回复: 1
ES15S improvement
发表于 2025-10-15 03:55:50 | 显示全部楼层 |阅读模式
Hello.
Will there be new firmware for ES15S?
What's the latest firmware?
There is a proposal to increase the information content of the work.
When impact is turned off, it is not clear when the torque limit was triggered.
I propose to make the screwdriver make a sound when the torque limit (tightening force) is triggered!
发表于 2025-10-15 09:11:08 | 显示全部楼层
Thank you for your suggestion. However, the ES15S uses its electric motor to simulate a horn sound, so it cannot produce audio while the motor is operating. The latest firmware for the ES15S is version V1.6, which can be downloaded here: https://forum.minidso.com/forum.php?mod=viewthread&tid=5650.
GMT+8, 2026-11-4 06:30 , Processed in 0.152853 second(s), 21 queries .
