查看: 1253|回复: 1
MDP-M01 bricked after failed update
发表于 2025-10-3 16:44:57 | 显示全部楼层 |阅读模式
Hi,
The original FW of my MDP M01 was v1.32.093 and I whould like to update to v2.02.001
I tried to copy several times the .hex file to the DFU (booted while holding A button) but got constantly an error  (filename with extention .err).
Next thing I tried was to copy the MDP_ADR.ADR file which was renamed to MDP_ADR.SET as discribed in the readme.txt. But the MDP M01 got bricked after I uploaded the bin file.
Now it constantly boots into DFU mode with a scrambled logo image on top, looks like the data has been corrupted.
When I try to install 1.32.093 again it also failes. Every time I try to upload a hex or bin image file to the DFU drive seems to disconnect from the PC and the image can't be uploaded.
Uploading the MDP_ADR.ADR still works and the DFU renames it to MDP_ADR.SET every time.
How can I debrick my MPD M01?
with kind rgards,
Ben Schueler
发表于 2025-10-9 09:47:09 | 显示全部楼层
What system are you using for the upgrade? Can you try using Windows 10?
GMT+8, 2026-10-31 13:43 , Processed in 0.155236 second(s), 21 queries .
