查看: 948|回复: 1
MDP-P906 turn off accidentally
发表于 2025-8-9 19:48:43 | 显示全部楼层 |阅读模式
https://cloud.mail.ru/public/MT95/8MyGrSb3S
 楼主| 发表于 2025-8-9 22:33:05
I returned 1.33 version. This glitch is disappeared.
发表于 2025-8-11 09:37:04 | 显示全部楼层
I can't open the video. Do you have more information? You can send an email to service@minidso.com
 楼主| 发表于 2025-8-11 16:15:01
At first, I updated my MDP-P906 to version 3.01 after I got it. It was the error. I returned 1.33 version, the problem is disappear. At first, my device is turned off at 100% cases if I use the shortcut button Set+Menu when I select a mode V/A. It happened not always, after some working time.
GMT+8, 2026-11-6 00:50 , Processed in 0.158664 second(s), 21 queries .
