查看: 1246|回复: 2
ES15S takes up to four run button presses to wake up
发表于 2025-8-6 17:03:02 | 显示全部楼层 |阅读模式
The ES15S takes up to four run button presses to wake up. Could you change the firmware to let the ES15S wake up on the first button press? Or could you add an option in the settings to let the ES15S stay on 10/20/30 minutes before it goes to sleep? As it is, it breaks the workflow.
发表于 2025-8-7 09:13:00 | 显示全部楼层
Why does my ES15S require four button presses to wake up?
Under normal operating conditions, the ES15S only requires pressing a button and turning a screwdriver to operate.
 楼主| 发表于 2025-10-1 22:04:46 | 显示全部楼层
Under normal operating conditions, the ES1 ...
Whenever you have set it to screw in or screw out only.
GMT+8, 2026-11-6 00:50 , Processed in 0.153940 second(s), 21 queries .
