查看: 1135|回复: 3
DS213 APP 1.28 BUG - freeze (hang up) if you would set 100ns sensitivity
发表于 2025-8-1 17:39:45 | 显示全部楼层 |阅读模式
DS213 APP 1.28 BUG - freeze (hang up) if  you would set 100ns sensitivity. Not only 1.28, any version. Rerun/hold helps. It has to be eliminated, specs item!
发表于 2025-8-4 09:51:18 | 显示全部楼层
Thanks for your feedback, we will test it and fix it if it is a bug.
发表于 2025-8-5 09:29:24 | 显示全部楼层
1. I tried to copy channel A to D as written in the documentation. It’s impossible. At first, call SaveWavXXX don’t save TRACKxxx.DAT, it save IMAGExxx.BMP. After that, if you were try to load (LoadWavXXX) then you would get the Error.
We have reproduced this BUG and it has been fixed now. Please wait for the new firmware to be released.
2. if you delete IMAGExxx.BMP then DSO213 is going crazy (zero level start random jumpings, calibration doesn’t helpful), may be, the device loses control and timing is broken.
3. freeze (hang up) if  you would set 100ns sensitivity. Not only 1.28, any version.
2 and 3 We haven't been able to reproduce this, could you provide further information? Video or pictures, please email me: service@minidso.com
 楼主| 发表于 2025-8-5 15:42:39 | 显示全部楼层
I replied with the email.
GMT+8, 2026-10-24 13:15 , Processed in 0.153698 second(s), 21 queries .
