查看: 1255|回复: 3
Cannot update firmware on MHP50
发表于 2025-6-4 23:10:04 | 显示全部楼层 |阅读模式
Hi
  I have just purchased the MHP50 on Amazon, and tried to download the latest firmware. I downloaded the files from the download page. As mentioned I copied across the MHP50APPxxx.hex file across first, it restarted, but never came up .rdy. It changed to .err. I have sent it back to get another one, and the next one simply done the same. I downlaoded the files a couple of times in case of issues, but was the same. I have also sent this one back, and ordered another. Can anyone tell me what the issue is?
Many thanks
Neil
发表于 2025-6-5 09:33:06 | 显示全部楼层
What operating system are you using? Can you try WIN7 and WIN10?
It is recommended to turn off the firewall and anti-virus software, and use the USB port directly from the computer motherboard.
If the ERR file still appears, it may be a compatibility issue with the WINDWOWS driver. Please try other computer.
 楼主| 发表于 2025-6-5 21:30:35 | 显示全部楼层
I am using Windows 10 Pro.  I use the USB/Serial on other peripherals , and works no problem. I restarted everything and still the same. After copying the file, resets and the file MHP50APPxxx.hex changes to MHP50APPxxx.err
发表于 2025-6-6 09:11:46 | 显示全部楼层
scsn 发表于 2025-6-5 21:30
I am using Windows 10 Pro.  I use the USB/Serial on other peripherals , and works no problem. I rest ...
Please email to service@morningtools.com , we will help you.
GMT+8, 2026-11-6 00:50 , Processed in 0.169218 second(s), 21 queries .
