查看: 1680|回复: 1
MHP50 firmware update
发表于 2025-4-26 21:37:30 | 显示全部楼层 |阅读模式
Is it possible to fix it?
Because my USB-C power supply was compatible with PD3.1.
So ,  the MHP50 was repeatedly rebooting.
Therefore, I tried to update firmware V2.1.
After following the procedure and MHP50APPV201.hex changed to MHP50APPV201.rdy, I copied MHP50UIV200.hex to MHP50, but it resulted in an error.
After that, no matter how many times I tried, the error occurred and I could not rewrite the firmware.
And now, when I plug in the USB-C power supply, it just displays the MINIWARE logo and won't work.
发表于 2025-4-27 11:07:49 | 显示全部楼层
What operating system are you using? Can you try WIN7 and WIN10?
It is recommended to turn off the firewall and anti-virus software, and use the USB port directly from the computer motherboard.
If the ERR file still appears, it may be a compatibility issue with the WINDWOWS driver. Please try other computer.
GMT+8, 2026-11-6 00:50 , Processed in 0.155910 second(s), 21 queries .
