查看: 1913|回复: 4
License Request DSO DS203
发表于 2025-1-24 03:27:00 | 显示全部楼层 |阅读模式
after an attempt to upgrade the firmware, my DSO203 (HW V2.72, Sys V1.62) with Serial No 8114B399 requests a License Key.
=> Can this license still be provided for such a device, please?
It also shows a FPGA Configuration Error - is the correct FPGA file still available for flashing?
Thanks!
  Henning
发表于 2025-1-24 09:43:18 | 显示全部楼层
License: 680EE7DD
But if it shows an FPGA error, you can only return it to the factory for repair.
 楼主| 发表于 2025-1-24 14:33:18 | 显示全部楼层
OK thanks for the quick answer.
Regarding the FPGA it tells "please load the FPGA data"...
And sorry - with 680EE7DD it tells a SYSTEM LICENCE ERROR.
Is there a second possible licence key for my serial #8114B399 ?
kind regards
 楼主| 发表于 2025-1-24 18:18:13 | 显示全部楼层
Hello and thanks for quick response.
Regarding the FPGA, it tells "please load the FPG data" - thats why I expected it can be solved by flashing.
After entering licence 680EE7DD at the start screen it tells a "System Licence Error!" - is there a second possible key for my serial #8114B399 ?
kind regards
Henning
发表于 2025-2-6 09:22:32 | 显示全部楼层
You can try the unlock code 52AB535A, but the FPGA error requires basic factory repair. If you can mail it back, we can help you repair it.
GMT+8, 2026-11-6 00:50 , Processed in 0.169872 second(s), 22 queries .
