查看: 1982|回复: 4
MHP50 Error 'No Plate'
发表于 2025-1-9 08:23:30 | 显示全部楼层 |阅读模式
Hi I recently started using the MHP50 and it was working OK, I upgraded to V2.0 and worked couple of times and then suddenly is giving me an error no matter if Reflow or heating, with USB-C (85W) or a DC brick 24v 10A, as soon it starts the process it shows a red message stating NO PLATE... there is no visible Icon of plate not connected, at the Info page it tells the temperature, and no errors. If I unplug the plate there is a red icon for no plate found and at the Info the Res is -- and Temp is -- so it sees it when the plate is not present or it is.
I reversed back to 1.01 by formating the drive, upgraded again and no luck, I need some help to get i fixed....
发表于 2025-1-9 09:03:48 | 显示全部楼层
Please send an email to service@morningtools.com, and we will help you solve it.
 楼主| 发表于 2025-1-9 09:11:55 | 显示全部楼层
Thank you, I sent it also included a small video capture
发表于 2025-11-7 17:05:36 | 显示全部楼层
我最近在使用MHP30时,也出现显示No hotplate故障情况,并且对设备进行出厂恢复操作,故障依旧,请帮忙分析指导一下故障原因,谢谢
发表于 2025-11-10 09:03:42 | 显示全部楼层
Mario_2025 发表于 2025-11-7 17:05
我最近在使用MHP30时,也出现显示No hotplate故障情况,并且对设备进行出厂恢复操作,故障依旧,请帮忙分析 ...
请发邮件至service@morningtools.com,我们会帮您处理。
GMT+8, 2026-11-7 03:16 , Processed in 0.148790 second(s), 21 queries .
