查看: 1309|回复: 2
Changes made under Menu do not stick 1.01 & 2.00
发表于 2024-12-17 03:33:41 | 显示全部楼层 |阅读模式
What I make changes in the Menu option they do not take effect when exiting the Menu option.
What do I o?
1) Push 'A' until Menu is displayed.
2) Push and hold 'A'
3) Make changes to Volume and Brightness
4) Reviewsettings, they are the changed values
5) Let the display timeout back to main screen
6) Go back into Menu to check values
7) Values ​​have changed back to old settings.
It does this in version 1.01 and 2.00
Bruce
发表于 2024-12-17 09:08:47 | 显示全部楼层
Timeout exit=exit without saving
Long press the B key to exit=save and exit
 楼主| 发表于 2024-12-17 09:52:55 | 显示全部楼层
Thank you!
GMT+8, 2026-11-6 00:50 , Processed in 0.158114 second(s), 21 queries .
