查看: 2135|回复: 2
[Troubleshooting] TS1C not saving config after firmware update to 1.6
发表于 2024-12-13 15:46:26 | 显示全部楼层 |阅读模式
after updating the station firmware using the file TS1C_APP_Ctrl_User_H180_V160.hex
when disconnecting power and connecting again, it forgets the config and goes back to 0 in the temp step
changing the temperature using the rotating knope doesn't work when first stating the iron,
going into settings I find that the temp step setting is 0
changing it 1 or any other value works
but disconnecting power and connecting again it goes back to 0
发表于 2024-12-16 10:39:40 | 显示全部楼层
What is your hardware version number? Can you take a video of the problem? Send it to service@minidso.com
Thanks!
 楼主| 发表于 2024-12-19 02:20:25 | 显示全部楼层
hardware version number 1.0
I fixed it by formatting the config drive in Windows to FAT because the config drive wasn't recognized after the firmware update and I wasn't even able to write files to it.
You should include that in the firmware update instructions. Thanks!
GMT+8, 2026-11-6 00:50 , Processed in 0.155670 second(s), 21 queries .
