查看: 1706|回复: 1
Unable to enter DFU mode on t80p soldering iron
发表于 2024-12-12 15:53:25 | 显示全部楼层 |阅读模式
Hello!
I can't enter DFU mode on a t80p soldering iron.
Ver Info T80P V:1.0.5.
I tried different wires, both the complete type-c - type-c, and from my phone type-c - usb-a. I connect the wire to the computer with one end. Then I clamp the button closest to the sting on the soldering iron and stick the other end of the wire into it. The soldering iron simply turns on as usual and shows the "Vol low" error, instead of switching to DFU mode. If I try to hold down the opposite button and connect it to the computer in the same way, then "Upgrading..." is shown on the screen and nothing else happens. The computer does not detect it under either windows or linux.
Can you please tell me what I have to do for the soldering iron to connect to the computer in DFU mode?
发表于 2024-12-13 09:23:36 | 显示全部楼层
How to enter DFU mode:
1. Press and hold the A button (the button near the soldering iron tip)
2. Connect TS80P to the computer via USB, and TS80P will display DFU xxx
3. A flash drive named DFU XXX will appear on the computer
The firmware file can be copied now.
Note that it is best to use the USB port directly from the computer motherboard, turn off the firewall and anti-virus software, and turn off the enhanced copy tool.
If you still have problems, please send the problem video to service@morningtools.com and we will help you solve it.
GMT+8, 2026-11-6 00:50 , Processed in 0.156141 second(s), 21 queries .
