查看: 1699|回复: 0
New member of MHP50 heating series - MHP50 Mini Soldering Station Adapter
发表于 2024-12-6 09:56:56 | 显示全部楼层 |阅读模式
The MHP50 mini constant temperature heating station can also be used as a soldering station?
That's right!
MINIWARE has launched the MHP50 mini soldering station adapter
Unlock the new gameplay of the MHP50 heating series
The MHP50 mini soldering station adapter is a new member of the MHP50 heating series and is also an extended function module of the MHP50 mini constant temperature heating station. It provides four models: SA80, SA115, SA210, and SA245. The MHP50 control end cooperates with different types of soldering station adapters to connect the corresponding compatible soldering iron handle and soldering iron tip to use as a mini soldering station.
Among them, when the SA80 soldering station adapter is used with the I-Stand soldering iron stand, it can also realize the instant sleep function, further improving the convenience of use.
(Warm reminder: Before use, the MHP50 control end firmware must be upgraded to V2.0 or above)
01.
Four models, free choice
MHP50 mini soldering station adapter includes four models: SA80, SA115, SA210, and SA245, which are compatible with TS80T series, 115 series (six-hole plug), 210 series (six-hole plug), and 245 series (six-hole plug) handles and soldering iron tips, respectively, to meet different needs and provide a wide range of choices.
(Among them, the SA80 model is equipped with: SA80 adapter, SA80 soldering iron handle, professional soldering iron tip, I-Stand soldering iron stand, and ground wire)
02.
Three-second ultra-fast heating
The fastest heating time of the SA115 and SA210 soldering station adapters is only 3 seconds (from room temperature to 300°C), making your soldering work time-saving and efficient.
03.
Two power supply modes
Supports PD and DC power supply modes. When powered by USB Type-C interface (supports firmware upgrade), it is compatible with PD2.0, PD3.0, and PD3.1 protocol power supplies, with an operating voltage of 20-28V and a maximum power of 110W; when powered by DC5525 interface, the operating voltage can reach 19V-24V and a maximum power of 110W.
04.
Instant sleep function
The SA80 mini soldering station adapter is equipped with a dedicated I-Stand soldering iron stand. The soldering iron handle can be put into sleep mode by simply placing it down, which is convenient and safe.
05.
SA80 soldering iron handle first indicator light
Fast flash - heating, slow flash - constant temperature
Easily check the heating status of the soldering iron
Product Parameters
Smart in small size, fun in creation
The launch of MHP50 mini soldering station adapter
is not only a new expansion of the MHP50 heating series functions
but also a new attempt by MINIWARE to bring you
a richer user experience
We believe
this new product will bring more inspiration and convenience to your work
We hope it can become a powerful assistant in your creative process
I hope you like it, please look forward to more innovations and surprises!
来源: 新品上市 | MHP50加热系列新成员——MHP50迷你焊台适配器
GMT+8, 2026-11-6 00:50 , Processed in 0.169990 second(s), 24 queries .
