查看: 3946|回复: 11
[使用心得] How to update MHP50 to version 2.00 firmware
发表于 2024-12-5 04:51:49 | 显示全部楼层 |阅读模式
How do I update my MHP50 to version 2.00 firmware?
My MHP50 is at version 1.02 now.
Thank you,
Bruce
发表于 2024-12-5 09:28:23 | 显示全部楼层
1. Download MHP50 firmware V2.0 and unzip it.
2. Long press the A button on the MHP50 console, connect the MHP50 to the computer with a USB Type-C data cable, enter DFU mode, the screen displays "DFU Mode V1.00", and a virtual disk "MHP50_DFU" will appear on the computer.
3. Copy the file "MHP50APPV200.hex" into the DFU disk, wait for the disk to restart and the "hex" file suffix to change to "rdy", then copy "MHP50UIV200.hex" into the DFU disk, wait again for the disk to restart and the "hex" file suffix to change to "rdy", disconnect the USB connection, and complete the firmware upgrade.
 楼主| 发表于 2024-12-6 04:14:53 | 显示全部楼层
The APP file worked first time I copied it over.
The UI file worked the second time I copied it over.
Thank you very much.
Bruce
 楼主| 发表于 2024-12-6 05:23:51 | 显示全部楼层
MHP50
Where do I find the version 1.02 firmware APPV and UIV if I decide to go back from version 2.00?
Also is there a new manual for version 2.00?  Where would I find it?
Thanks,
Bruce
发表于 2024-12-6 09:30:49 | 显示全部楼层
blakebr 发表于 2024-12-6 05:23
MHP50
Where do I find the version 1.02 firmware APPV and UIV if I decide to go back from version 2.0 ...
The upgrade of V1.02 is not significant, so it is not available for download.
 楼主| 发表于 2024-12-7 01:20:10 | 显示全部楼层
Do I need a "MHP50UIV1.01.hex" if I want to go back from 2.00?
Do I delete the two 2.00 files in the MHP50 first?
Will there be a MHO50 Version 2.00 manual explaining the differences?
Thank you,
Bruce
 楼主| 发表于 2024-12-8 00:54:23 | 显示全部楼层
Is there a new manual for version 2.00? Where would I find it?
发表于 2024-12-9 09:08:22 | 显示全部楼层
Here: https://forum.minidso.com/forum.php?mod=viewthread&tid=5652
 楼主| 发表于 2024-12-10 08:31:26 | 显示全部楼层
Thank you,
Bruce
发表于 2024-12-11 09:05:10 | 显示全部楼层
Do I delete the two 2.00 files in the ...
Not need delete 2.0 files.
GMT+8, 2026-11-6 00:50 , Processed in 0.159279 second(s), 22 queries .
