查看: 1798|回复: 1
[使用心得] TS101 switch off with Anker 715 Nano II 65W
发表于 2024-11-25 01:17:04 | 显示全部楼层 |阅读模式
I'm using a TS101 soldering iron with the most current firmware (V2.10) and I'm trying to power it with an Anker 715 Nano II 65W power supply (A2663), which supplies up to 65W with PD 3.0.
The TS101 heats up, but when reaching the target temperature (300C) it switches off and restarts after a couple of seconds.
With another Anker power supply (Anker 735 GaN Prime 65W A2668) this problem does not occur.
I tried both the MINIWARE PD3.1 USB-C cable as well as other brand USB-C cables (mostly Anker), with the same behavior.
Question: Is there a newer firmware available? Is this a known problem?
Thanks in advance!
Arnd DJ9PZ/AB2QP
发表于 2024-11-25 09:14:35 | 显示全部楼层
In standby mode, long press the A button to display the internal resistance of the soldering iron tip.
GMT+8, 2026-11-6 00:50 , Processed in 0.159011 second(s), 21 queries .
