查看: 3059|回复: 4
[疑难问题] DS213一直进入DFU模式。
发表于 2024-11-16 13:12:35 | 显示全部楼层 |阅读模式
DS213一开机先显示加载界面
【digital storage oscilloscope
FPGA Configration Err!
Please Load the FPGA Data】
然后就进入了下面这个界面
Serial:9689C39E Licence:B538881
Device Firmware Upgrade V3.73C
Please copy Hex or Bin file tothe DFU virtual USB disk】
如果,开机时同时按暂停键是直接进入DFU模式界面。还是上图那个界面。
我更新了DS213AppV1.28_Chinese和DS213AppV1.28_Chinese固件都不行,没有找到V3.73C?
发表于 2024-11-18 09:13:26 | 显示全部楼层
V3.73 是DFU的版本号,不需要升级
现在你这个状态,是升级APP出错造成,请尝试以下方法解决:
1.进入DFU模式
2.拷贝需要更新的APP的HEX文件(比如APPV1.28中文版固件)进DFU盘
3.DFU盘会刷新,然后HEX文件后缀名会变为RDY
4.完成升级
如果没有见到RDY文件,请需要尝试其他电脑更新,建议使用WINDOWS系统,并且用主板直出的USB口更新。
发表于 2024-12-22 20:05:05 | 显示全部楼层
Thank you very much, I just managed to get the DS213 running again, I used a different PC and the update worked.
Thanks for the quick help !!!
发表于 2025-5-8 13:35:13 | 显示全部楼层
my DS213 is stuck in DFU mode.
When I boot it up a screen flashes for less than a second that says "FPGA Configuration Error! Please load the FPGA"
Then it go to the main DFU screen that says Device Firmware Upgrade V3.76C.
Iv tried flashing back to an older firmware, 1.27, following the steps in the read me file. The FPGA file and the BIN file copy over as they are supposed to but when I go to load the hex file it always says err. It does this if I try to load the 1.28 firmware as well. Iv tried 2 different computers running windows with no luck. Any advice?
发表于 2025-5-9 09:30:34 | 显示全部楼层
When I boot it up a screen flashes for less than a second that says " ...
Can you try to upgrade FPGA? Here can download FPGA018
https://forum.minidso.com/forum.php?mod=viewthread&tid=3357
GMT+8, 2026-11-6 00:50 , Processed in 0.155682 second(s), 21 queries .
