查看: 2143|回复: 5
TS1C NO TIP! Issue
发表于 2024-10-22 16:25:21 | 显示全部楼层 |阅读模式
Hey!
After several hours of use, my soldering station suddenly started displaying the message NO TIP! and the tip stopped heating up. I contacted the seller, who provided the firmware file "TS1C_pen_APP_NoHight_R_Test.hex" sized 285765 bytes to fix the problem. But after I transfer the firmware file to the soldering iron as per the instructions, the file gets renamed to "TS1C_P~1.ERR".
Please help with the solution!
发表于 2024-10-23 09:25:38 | 显示全部楼层
Please send an email to service@morningtools.com, and we will help you solve it.
 楼主| 发表于 2024-10-23 23:18:51 | 显示全部楼层
E-mail has sent, waiting for the answer.
发表于 2025-2-7 08:39:41 | 显示全部楼层
I reflashed the soldering iron on the computer at work. The home computer gave the same error.
发表于 2025-9-27 00:44:43 来自手机 | 显示全部楼层
I had the same problem: updating firmware on windows 10 returns .ERR firmware file, but on another my Windows 7 laptop it's OK (.RDY).
GMT+8, 2026-11-6 00:50 , Processed in 0.156675 second(s), 21 queries .
