查看: 1442|回复: 1
but could be improved further.
发表于 2024-10-16 05:57:52 | 显示全部楼层 |阅读模式
I bought your screwdriver.
Made very high quality, but could be improved further.
1. Main button - the finger does not always find it.
I added a small stainless steel ball to it - it became much more convenient.
2. If you use a screwdriver like a regular one (sometimes necessary), your fingers get on the display, and it makes a lot of crunches and clicks.
I applied viscous silicone gel around the perimeter of the display glass (shown by the red arrow), from the inside - the creaking and crackling disappeared.
3. The magnetic fixation of the bit is weak. I added a small cylindrical magnet inside.
4. The screwdriver spindle locking mechanism did not always work, about 6 times out of 10. This was very annoying.
Perhaps this is a consequence of a stronger magnet that influenced the cylinders. I measured the diameter of the cylindrical “crackers” of the locking mechanism to be about - 1.95mm
I machined cylinders with a diameter of 2.05mm from stainless steel, which is absolutely non-magnetic. After this, the spindle locking mechanism began to work perfectly.
Please improve:
1. Reduce the delay between the start of manual rotation and automatic rotation. It’s annoying to wait every time for automatic rotation to start.
2. Create a mode in which the start occurs immediately at maximum speed, without annoyingly slow acceleration of rotation. This point is very important!
发表于 2024-10-16 09:11:35 | 显示全部楼层
Thanks for your suggestion, we will test the locking mechanism and other suggestions.
GMT+8, 2026-11-4 06:28 , Processed in 0.150423 second(s), 21 queries .
