查看: 1520|回复: 4
[Troubleshooting] voltage drop >1V increment
发表于 2024-9-20 16:31:58 | 显示全部楼层 |阅读模式
When using the MDP-M01 to decrease the voltage of a MDP-906 with increments of 1V or larger, is see the voltage drop significantly lower than the setpoint. After a short time (<0.5s) it recovers to the desired voltage. What could be the cause of this?
This happend when the load was a 24V fan and with a pure resistive load. The firmware of both devices are the latest available
Kind regards,
Aaron
 楼主| 发表于 2024-9-23 22:55:46 | 显示全部楼层
attached an image to show the problem
Scan - 2024-09-23 16_53_22.pdf (375.38 KB, 下载次数: 583)
发表于 2024-9-24 14:33:46 | 显示全部楼层
From the phenomenon you reported, it seems that the anti-backflow protection has been triggered. The set voltage is suddenly lower than the current voltage, and the capacitor voltage will not be turned on again until it drops below the set voltage. The inertia of the fan may prolong this process.
 楼主| 发表于 2024-9-25 02:07:11 | 显示全部楼层
Thanks for the reply. I suspect that this is indeed the issue. Although it also happens with a normal resistor. So could it be the anti-back flow protection is set to aggresive?
发表于 2024-9-25 09:10:26 | 显示全部楼层
gitaaron 发表于 2024-9-25 02:07
Thanks for the reply. I suspect that this is indeed the issue. Although it also happens with a norma ...
This may be the reason.
GMT+8, 2026-11-6 00:50 , Processed in 0.167217 second(s), 24 queries .
