查看: 2069|回复: 5
MHP50 and USB PD Power issues
发表于 2024-8-28 05:54:43 | 显示全部楼层 |阅读模式
I recently picked up the MHP50 from Adafruit. It wasn't able to get very hot, I assume because my USB-C charger doesn't support the higher voltages. So I picked up a USB-C charger from my local BestBuy that supports 5V@3A, 9V@3A, 15V@3A, 20V@5A and 28V@5A. Unfortunately the hot plate doesn't even power up with this charger. I'm assuming that means there's a glitch in the USB-C power negotiation . So I went looking for a firmware update.
I see it's loaded with the 1.02 firmware, which oddly isn't even mentioned on the manufacture website.
https://e-design.com.cn/en/NewsDetail/4203645.html
Is there a firmware update that supports a wider range of USB-C charger negotiations?
发表于 2024-8-28 09:20:50 | 显示全部楼层
MHP50 supports standard PD protocol power supply. Please do not use charging heads with modified protocols from third-party manufacturers. The following charging heads have been tested to drive MHP50.
Beisi Gallium Nitride GaN5Pro
Green Alliance CD289
AohiAOC-C012
AppleA2452
Green Union Energy Pai Series Power Bank
 楼主| 发表于 2024-8-29 00:47:29 | 显示全部楼层
As far as I know the BestBuy power supply is standard, unmodified and widely sold.
That power supply list is very short, are you supporting the standard charging negotiation protocols? Perhaps there's a firmware update to do so?
 楼主| 发表于 2024-8-29 01:13:32 | 显示全部楼层
That's a very short list.
The Apple A2244 is only 9VDC and 20 watt. That doesn't seem useful for heating.
Could we get a firmware update to support higher wattage options from more USB-C PD supplies?
发表于 2024-8-29 09:10:07 | 显示全部楼层
The Apple A2244 is only 9VDC and 20 watt. That doesn't seem useful for h ...
Sorry, it's an Apple A2452 140W charging head.
We are also trying to upgrade the software to improve PD compatibility, please wait.
发表于 2025-1-13 01:00:25 | 显示全部楼层
Firmware version 2.01 is now available.
Check out the SM100CL-01 power brick from Amazon.  It works great with my MHP50 with 2.01
Bruce
GMT+8, 2026-11-6 00:50 , Processed in 0.155690 second(s), 22 queries .
