查看: 8581|回复: 21
[Troubleshooting] MDP-P906 turns on and instantly off when powered via USB-C PD
发表于 2024-7-31 01:50:44 | 显示全部楼层 |阅读模式
Hej,
I have two MDP-P906 which are working very well on differnt USB-C PD power supplies but not on the "HSSNS USB-C 570W" (https://amzn.eu/d/0dBUtaUD) device I purchased recently.
The MDP-P906 turns on flickers shortly and turns off again. I see the same behaviour on all the USB-C ports on the "HSSNS USB-C 570W" for both MDP-P906 I own.
I updated all devices to the latest firmware because it stated "Improve the compatibility of P906 with the power supply head with PD protocol" (MDP-P906: v1.33, MDP-M01: v2.02) but unfortunately it didn't solve the issue.
The "HSSNS USB-C 570W" is otherwise working fine - no problem with other devices like laptops, mobile phones, USB-PD Decoy, ...
Do you think there is a chance to fix the firmware to "make it work"?
Here is a video of the problem:
https://youtu.be/vNfNJiAXdrw
Thanks!
发表于 2025-1-10 09:22:09 | 显示全部楼层
Toomas 发表于 2025-1-10 04:16
Hello! I have similar problem. Just purchased Ugreen Nexode 200W power bank (https://eu.ugreen.com/c ...
I don't have the model of mobile power you mentioned, so I can't test it.
But if this mobile power supports the standard PD protocol (not the protocol modified by the manufacturer) and supplies power to the P906 through the C2C power cable, then it is possible.
回复 1 0
发表于 2024-9-2 08:56:40 | 显示全部楼层
Botech 发表于 2024-8-31 00:30
Could it be that it's not supported when PPS, programmable power supply, is supported.  I have a 3 ...
We will test this issue and continue to improve the compatibility of P906 through software upgrades.
回复 1 0
 楼主| 发表于 2024-8-20 13:57:18 | 显示全部楼层
Thanks a lot!
回复 0 1
发表于 2024-8-12 10:00:44 | 显示全部楼层
beo 发表于 2024-8-9 23:14
I returned the "HSSNS USB-C 570W" it was making trouble on to many other devices as well...
It is recommended to use a power supply with standard PD protocol for power supply.
For example:
Beisi Gallium Nitride GaN5Pro
Green Alliance CD289
AohiAOC-C012
AppleA2244
Green Union Energy Pai Series Power Bank
回复 0 1
发表于 2024-7-31 09:06:02 | 显示全部楼层
HSSNS USB-C 570W
All USB-C1 to C5 can't power on MDP-P906?
Or only C1 C2 can't power on?
 楼主| 发表于 2024-7-31 14:35:38 | 显示全部楼层
Thanks for the quick answer - I tested it on all ports:
The only port that works is C5 (the one marked 30 W).
C1, C2 (140 W) -> Not working
C3, C4 (100 W) -> Not working
C5 (30 W) -> working
I even tried different cables that I had tested with other USB-C power supplies and they worked fine with the MDP-P906 - so I would rule out the cables being faulty.
 楼主| 发表于 2024-7-31 15:43:15 | 显示全部楼层
I just noticed something on the TS80P solder iron (IronOS V2.22).
The TS80P powers on but only negotiates QC and 5 Volt on Port C1 and C2.
On C3, C4 and C5 it negotiates PD with 12 Volt
TS80P on "HSSNS USB-C 570W":
C1, C2 -> QC + 5 V
C3, C4, C5 -> PD + 12 V
发表于 2024-8-1 09:16:46 | 显示全部楼层
According to your description, it should be a compatibility issue. I will look for detailed information about this PD power supply, such as what protocol chip it uses, and then evaluate whether it can be made compatible with this power supply through software upgrades.
 楼主| 发表于 2024-8-1 15:32:02 | 显示全部楼层
minidso 发表于 2024-8-1 02:16
According to your description, it should be a compatibility issue. I will look for detailed informat ...
Thanks a lot!
Let me know if I can help or provide more information.
发表于 2024-8-4 03:24:56 来自手机 | 显示全部楼层
hello. same problem I had on Xiaomi PD 67w charger and UGREEN PB720 PD 100w power bank.
it will work fine with QC 3.0 charger and PD 20w power bank.
also all power banks and charger works fine if I use PD 20v trigger, by powering p906 from DC port
发表于 2024-8-5 09:13:16 | 显示全部楼层
Xiaomi PD 67w charge is a charger with modified PD protocol, MDP-P906 does not support it now。
 楼主| 发表于 2024-8-9 23:14:26 | 显示全部楼层
GMT+8, 2026-11-6 00:50 , Processed in 0.181137 second(s), 23 queries .
