查看: 4215|回复: 2
MDP-M01显示控制模块固件V2.01版发布 TS101 / MDP-M01 firmware V2.01 released
发表于 2024-7-2 16:09:50 | 显示全部楼层 |阅读模式
增加GRID多格页面。
GRID多格页面使用方法:
长按按键”GRID”,进入多格页面;
单击按键”GRID”,切换格子数;
单击按键“SHOW”,打开/关闭波形显示窗口。
升级方法:
按住M01的A键,同时使用Micro-USB数据线将M01与电脑连接,电脑将出现名为:DFU Vx_xx_x的可移动磁盘,将准备好的.hex固件拷贝到该移动磁盘的根目录下,当固件后缀名变为.rdy后,重启M01,完成固件升级。
Added GRID multi-grid page.
How to use the GRID multi-grid page:
Press and hold the "GRID" button to enter the multi-grid page;
Click the "GRID" button to switch the number of grids;
Click the "SHOW" button to open/close the waveform display window.
How to upgrade:
Press and hold the A key of M01, and use the Micro-USB data cable to connect M01 to the computer. A removable disk named DFU Vx_xx_x will appear on the computer. Copy the prepared .hex firmware to the root directory of the removable disk. When the firmware extension is changed to .rdy, restart M01 to complete the firmware upgrade.
下载地址 / Download address: https://forum.minidso.com/forum.php?mod=viewthread&tid=3685
发表于 2025-2-13 00:30:09 | 显示全部楼层
i have tried to update the M01 to V2.01.
After entering the DFU-mode and copying the .hex file to the drive, the file ending changed to .err and now the device will noit exit the dfu mode.
also trying as described in in the readme.txt: first .Adr file -> changed to .SET, then load the .bin file -> changed to .rdy.  does not work and the device stays in dfu mode ... what can i do?
i have trief to find something with the search function, but it is not easy with the language..
thanks and best regards!
 楼主| 发表于 2025-2-13 09:15:26 | 显示全部楼层
What system is your computer running? We recommend using WIN10, turning off firewall and anti-virus software, and using the USB port directly connected to the computer motherboard.
GMT+8, 2026-11-5 19:47 , Processed in 0.162304 second(s), 24 queries .
