查看: 1900|回复: 1
ts80p software issue
发表于 2024-6-4 21:01:37 | 显示全部楼层 |阅读模式
hi, i've recently bought a ts80p iron but i can't use it for the following reason: No tip found& Z: Y8 [4 q8 s5 N% p" G
6 t9 w7 z% i. l! p$ A- u7 r) Z% q
+ m, c6 W8 n4 k2 T9 nso before comming on this forum, i tried a few things, mainly:7 x8 S+ H' ?; @
, W: z) S+ @, Z' I6 ^
checking if the tip was properly plugged in, that didn't fix the issue
# R+ s( z8 x5 D* U% U3 f$ P+ `/ q7 H* l# V
checking the power given to the iron, that didn't fix it either
& r% n* f2 y7 N1 h  p& g# e$ `7 n7 o% @1 J! Z" H. V( n8 C7 t  G1 ^
checking the software and reinstalling it, that didn't fix it.
$ Q1 k8 N9 Q! s; e9 m& Q% {6 y6 g  b; ~* N/ d0 P" o
" p+ `2 D: n, n# V+ ]
So i'd like to know if it is possible to wipe out the bootloader and software to reinstall a previous version, because right now if i try to install a previous version, the output of it is a .ERR file (i tried redownloading a bootloader from miniware's github, tried to pass the bootloader, got a .ERR, tried the runtime, got .ERR, i tried to look into it but they all gave me .ERR, the only .RDY i got was when reinstalling the 1.3 version, which is the faulty one)
6 {2 R2 [$ X; t/ r+ ~& t, ~
发表于 2024-6-5 09:06:49 | 显示全部楼层
Please send an email to service@morningtools.com, and we will help you solve it.
GMT+8, 2026-11-15 14:22 , Processed in 0.162688 second(s), 21 queries .
