查看: 2366|回复: 1
[Troubleshooting] defect and no DFU after failed firmware update
发表于 2024-5-5 23:16:17 | 显示全部楼层 |阅读模式
I've the ES15 and so far it worked perfectly fine. But during the last firmware updated it reconnected before the file extension was changing back to ".rdy".
Since then the display is dead, the screwdriver is dead and I can't get it into DFU Mode anymore. When I hold the SET Button while connecting it makes no difference. I get only the config.txt file in the APP Mount.
Is there any other fallback method to get into DFU Mode or flash the firmware again?
I've contacted service@morningtools.com a few days ago but didn't got a respons so far, so I'm not sure if my eMail went through.
Leif
发表于 2024-5-6 09:13:10 | 显示全部楼层
Please email to service@minidso.com and we will help you.
GMT+8, 2026-11-4 06:32 , Processed in 0.154039 second(s), 21 queries .
