查看: 1696|回复: 1
Not heating above 80'c
发表于 2024-4-19 23:43:14 | 显示全部楼层 |阅读模式
I just bought an MHP50-B5. When I connect it to a 10A supply at 24V, and put it into heat mode, it heats up but only gets as far as just over 80'c.
I increased the amount of power it can draw in the settings menu to 150W but it made no difference.
No warnings are being displayed - the unit just never gets any hotter.
I used an IR temp measurement device and the hot plate is about 10'c warmer than what the display says.
Can you help - is the unit defective or am I doing something wrong?
Many thanks,
Murdo.
发表于 2024-4-22 09:34:58 | 显示全部楼层
Please email the video or picture of probrom to service@minidso.com
We will help you.
GMT+8, 2026-11-6 00:56 , Processed in 0.158227 second(s), 21 queries .
