查看: 2603|回复: 5
[Troubleshooting] The TS101 grounding point does not connect to the tip
发表于 2024-4-10 20:04:28 | 显示全部楼层 |阅读模式
The instructions say that the resistance from the tip to ground is 2 ohms, but it is not. Also this does not work with the ground cable. The gound point connect with the dc cable ground. What about grounding the tip?
发表于 2024-4-12 09:31:24 | 显示全部楼层
The current design of TS101 is to connect the ground point and the DC ground. If the soldering iron tip needs to be grounded, the soldering iron tip needs to be connected to the ground separately.
 楼主| 发表于 2024-5-2 00:38:27 | 显示全部楼层
Can I do some manipulation with the soldering iron board that connects the tip and the ground point?
 楼主| 发表于 2024-5-2 01:12:30 | 显示全部楼层
minidso 发表于 2024-4-12 09:31
The current design of TS101 is to connect the ground point and the DC ground. If the soldering iron  ...
发表于 2024-5-6 09:35:21 | 显示全部楼层
leonard-pak 发表于 2024-5-2 01:12
Can I do some manipulation with the soldering iron board that connects the tip and the ground poin ...
It‘s not recommended.
GMT+8, 2026-11-6 00:53 , Processed in 0.196566 second(s), 24 queries .
