查看: 3089|回复: 5
Licence Key Request DSO 203
发表于 2023-12-2 03:10:54 | 显示全部楼层 |阅读模式
Greetings everybody,
I own an DSO 203 Oscilloscope and after a long time not using it, I had to replace the battery, but then I was stuck at the boot. It just shows a blank, white screen. After a research it seems that the FW has an error and I decided to re-flash the FW with a tool from STMicroelectronics. Now, there IS a boot screen, but it says "System Licence Error!". Based on the Information here in this forum, I want to request the Licence Key for my device:
Hardware Version: 2.81
Serial Number: 7931AF78
Hope somebody of this company can help me.
Sincerely
TheAmadeus25
发表于 2023-12-5 09:14:33 | 显示全部楼层
Please try AFC00A01
 楼主| 发表于 2023-12-11 06:34:36 | 显示全部楼层
Thank you very much! It worked without any problems.
Sincerely
TheAmadeus25
 楼主| 发表于 2023-12-11 07:08:43 | 显示全部楼层
Thank you very much! It worked without any problems!
Sincerely
TheAmadeus25
发表于 2026-10-21 18:36:58 | 显示全部楼层
I know it has been years since the last post but hopefully somebody is still monitoring.
I also pulled out my old DS203 and had to unbrick it and now I need a licence.
Serial Number: 79339F9A
发表于 2026-10-22 09:14:02 | 显示全部楼层
I also pul ...
Please try 3124F41D
GMT+8, 2026-11-5 19:47 , Processed in 0.151632 second(s), 21 queries .
