查看: 2153|回复: 1
[Troubleshooting] Using two MDP-P906 in Parallel or Series
发表于 2023-8-16 08:16:01 | 显示全部楼层 |阅读模式
Are there any instructions or steps to correctly use two MDP-P906 units in parallel for current sharing or series for higher voltage range? I also have the MDP-M01 monitor if there are any settings in there to configure that will support this desired  configuration.
发表于 2023-8-16 09:27:53 | 显示全部楼层
MDP-P905 and MDP-P906 support series voltage boosting and parallel current sharing. The usage is the same as other power supplies, but it should be noted that the same power supply cannot be used for power supply. Each power module needs a separate power input.
GMT+8, 2026-9-23 22:07 , Processed in 0.183237 second(s), 21 queries .
