查看: 2009|回复: 4
License please
发表于 2023-7-30 12:36:17 | 显示全部楼层 |阅读模式
DS 203 v2.70 Serial 2612E08D
Thank you!
发表于 2023-7-31 09:20:57 | 显示全部楼层
Please try 69C799CA
 楼主| 发表于 2023-8-1 12:57:32 | 显示全部楼层
That does not work; I get 'License input error'. However, this is after I flashed the DSU via the on board pins to try to make it work with Windows 10, and the display now says 'Hardware ver v2.72', so maybe that is why? Could you please regenerate a license as it were 2.72?
 楼主| 发表于 2023-8-1 13:26:13 | 显示全部楼层
I read in https://minidso.com/forum.php?mod=redirect&goto=findpost&ptid=905&pid=8852 that "The DPU and FPGA must used 2.72 for older HW." so I flashed with a DFU for 2.72, but it looks like that was wrong. The license is not accepted and the device now shows as 8MB storage (but the storage is unusable). Is there a DFU for 2.70 that I can flash to fix it? Especially one that works for Windows 3.10 too, which is what I was trying to make work by doing this?
发表于 2023-8-2 09:24:04 | 显示全部楼层
If your serial number is 2612E08D
Then your license is 69C799CA or CF867896
GMT+8, 2026-11-6 00:59 , Processed in 0.149705 second(s), 21 queries .
