查看: 2909|回复: 3
Signal not saving to flash
发表于 2023-7-15 10:44:15 | 显示全部楼层 |阅读模式
The starting screen shows
"Correction..........
parameter record not found"
and also fails to save any signal data(shows Error when I try to do it).
Please help.
发表于 2023-7-17 09:15:05 | 显示全部楼层
Please format the built-in flash disk (not DFU disk) of DS213 to "FAT" format, then you can save the configuration file.
 楼主| 发表于 2023-7-23 00:46:32 | 显示全部楼层
OK is it specifically FAT12 or FAT16?
发表于 2023-7-24 10:02:36 | 显示全部楼层
It's "FAT" in windows system.
GMT+8, 2026-11-6 00:59 , Processed in 0.151794 second(s), 21 queries .
