查看: 5877|回复: 6
Material Download For TS1C Cordless Soldering Station
发表于 2023-6-28 09:53:05 | 显示全部楼层 |阅读模式
2023.06.28:http://forum.minidso.com/forumdownload/TS1CAPPV160.zip
TS1C Cordless Soldering Station APP V1.60:
- Added Chinese/English/Russian/German multi-language
- Changed the Bluetooth disconnection to the settings page, and added disconnection confirmation logic
- Solved the conflict problem of the base PD applying for voltage again after the last voltage application was not completed
- Modified the base PD application voltage time interval
- Optimized the base current limiting protection recovery to avoid repeated triggering
- Optimized the handle preheating power
2023.06.28:
TS1C Cordless Soldering Station UserUser Manaul CN EN RU V1.2: http://forum.minidso.com/forumdo ... l.CN.EN.RU.V1.2.pdf
发表于 2023-7-2 13:11:09 | 显示全部楼层
Any chance of getting schematic/specs/firmware update? What CPU does it use?
发表于 2023-7-5 10:54:58 | 显示全部楼层
Ok got it. It's CH579 for the station, I assume it's CH579 for the iron as well.
发表于 2024-12-14 09:59:01 | 显示全部楼层
after updating the station firmware using the file TS1C_APP_Ctrl_User_H180_V160.hex
when disconnecting power and connecting again, it forgets the config and goes back to 0 in the temp step
changing the temperature using the rotating knope doesn't work when first starting the iron,
going into settings I find that the temp step setting is 0
changing it to 1 or any other value works
but disconnecting power and connecting again it goes back to 0
Where can the old firmware files be found until this is fixed?
 楼主| 发表于 2024-12-16 10:39:44 | 显示全部楼层
What is your hardware version number? Can you take a video of the problem? Send it to service@minidso.com
Thanks!
发表于 2025-2-19 05:59:52 | 显示全部楼层
Where can I download the latest firmware?
 楼主| 发表于 2025-2-19 09:18:15 | 显示全部楼层
V1.6 is the newest firmwar of TS1C
GMT+8, 2026-11-6 00:50 , Processed in 0.182471 second(s), 21 queries .
