查看: 10024|回复: 6
Flashing .hex files
发表于 2014-2-16 00:59:13 | 显示全部楼层 |阅读模式
When I connect my DS203 to the computer with the USB cable, hold down the >|| button, it appears in Windows Explorer as a new drive. - all well and good, but...
When I try to copy a file to it, the computer responds with  'no Such drive' and it disappears from Windows Explorer.
It doesn't matter what type of file I try to copy.
Tried Windows 7 and Windows XP. Same problem.
Can anyone help ?
发表于 2014-2-16 09:33:27 | 显示全部楼层
Please change the usb cable , and try again .
销售店铺  ccdso.taobao.com
(Miniware代理商)
 楼主| 发表于 2014-2-16 18:05:27 | 显示全部楼层
Changed the cable but no difference.
If I connect the DS203 to my computer and just switch on, I can copy files to the device then (it's just named DSO and has one file there - 9220AA97.PAR).
It's only when I hold down the >|| key and switch on, that it doesn't work (it's then named DFU V3_12_C and contains no files)
All the drivers loaded OK, I have even uninstalled them and tried again from scratch. One of them is called 'Vertual DFU Disk USB Device'. I assume that the bad spelling of 'Virtual' is OK?
Any other ideas?
Regards,
Paul
发表于 2014-2-17 10:18:11 | 显示全部楼层
Under  windows7 and windows xp will be no such problem.
Have you ever tried other computer?
 楼主| 发表于 2014-2-17 22:28:04 | 显示全部楼层
Re:Flashing .hex files - can't copy to DFU
Yes!
I have tried 3 different computers:
Windows 7 x64
Windows 7 x86
Windows XP
Same problem on all of them.
发表于 2014-2-18 14:15:07 | 显示全部楼层
回 fishman 的帖子
fishman:Yes!
Windows 7 x64
Windows 7 x86
Windows XP
.......?(2014-02-17 22:28)?
The question now is: you can't copy the files into DFU mode?
 楼主| 发表于 2014-2-18 16:36:23 | 显示全部楼层
That is correct.
I can't copy anything in DFU mode.
When I try to copy a file, the PC waits for a few minutes, then responds with 'no such drive'
GMT+8, 2026-11-15 13:29 , Processed in 0.158353 second(s), 22 queries .
