查看: 7103|回复: 6
[Troubleshooting] TS101 - No Tip Message
发表于 2023-2-8 00:15:16 | 显示全部楼层 |阅读模式
I replaced the original TS-B2 tip with a TS-D24 tip and when the soldering iron heats up I get the NO TIP message. Long pressing 'A' key says the tip resistance is 7.8 ohms. Is this normal? What else can I check?
发表于 2023-2-8 09:11:44 | 显示全部楼层
Please send an email to service@morningtools.com, and we will help you solve it.
发表于 2023-5-16 00:04:16 | 显示全部楼层
Hi,
I replaced the original TS-1 tip with a TS-K tip and when the soldering iron heats up above 360 degrees Celsius I get the “NO TIP” message
Is the TS-K tip is faulty?, or is the soldering iron faulty? Or is this normal?
Cheers,
Deon
发表于 2023-5-16 09:16:20 | 显示全部楼层
发表于 2023-7-5 22:45:02 | 显示全部楼层
Im having the same problem even with original MINI tips. I thought it was a bad iron so i got another and same issue. Ive sent a message to service@morningtools.com with no response. My Pine64 Pencil V2 has not problem using any of the 6 tips i have including MINI tip and heats up to 450c.
I would like some help to get this fixed thank you.
发表于 2023-7-6 10:01:24 | 显示全部楼层
Will check email, please wait for reply.
GMT+8, 2026-11-6 00:59 , Processed in 0.169456 second(s), 24 queries .
