查看: 4161|回复: 5
[Others] Solder Tip Microwave BCM2 ⇒ TS-BC2
发表于 2023-1-2 01:34:28 | 显示全部楼层 |阅读模式
Many people use the BCM2 tip to solder multi-pin chips. It is very comfortable and creates a microwave. Are you planning production ? You can try to make a TS-BC2 tip based on it.
发表于 2023-1-3 09:10:59 | 显示全部楼层
Thanks for your suggestion, we will test it.
回复 1 0
 楼主| 发表于 2024-2-29 04:47:41 | 显示全部楼层
Any news ?
发表于 2024-2-29 09:13:46 | 显示全部楼层
Sorry, the demand is too low for us to mass produce.
 楼主| 发表于 2024-3-2 08:22:48 | 显示全部楼层
It's a pity. BCM2 is selling well. They are easy to solder multi-legged contacts of the microcircuit
GMT+8, 2026-11-6 00:59 , Processed in 0.179400 second(s), 28 queries .
