查看: 8558|回复: 1
One more in DSO203 community
发表于 2014-1-25 22:53:07 | 显示全部楼层 |阅读模式
Hi,
So, all is on tittle, but I have just some questions...
First of all, I found DSO-203 - 2.7b- sys v1.6 on aliexpress...
I just want to know more about hardware version, between many over versions and the 2.72 (beta version? or last one and since when?).
And to finish, options i have about 3 overs app? I found many web sites like seeedstudio, but it's more interesting to ask this directly  with users...
tybo
发表于 2014-2-10 17:35:36 | 显示全部楼层
(1)
     2.7b  is 2M flash version
     2.72  is 8M flash version
     DS203 V2.72 version will 2M built-in flash changed to 8M, need to cooperate with SYS_160
     used at the same time, application firmware gm, other no change.
(2)
     DS203 boot, if only electrical switches, the default open firmware 1, hold down the "■"
     electrical switches open firmware 2 at the same time, hold down the "●" at the same time
     open firmware 3 electrical switches, press and hold "▲" electrical switches open firmware 4      at the same time.
     PA1_V110 “PA1” represents the first area procedure, “PA3”  represents the third area
     procedure, The new program takes two app partitions, normally only install two apps.
GMT+8, 2026-11-15 13:29 , Processed in 0.148069 second(s), 21 queries .
