查看: 4123|回复: 0
[Sharing /User Voice] The long-awaited MINIWARE Smart Soldering Iron TS101 is finally here!
发表于 2022-10-20 16:14:11 | 显示全部楼层 |阅读模式
NEW ARRIVAL!!!
As an upgraded version of TS100, it has been optimized in performance and function. Users will have a better experience.
Remove Tip Directly
Different from TS100, the way of removing tip of TS101 is much easier and convenient. No need to loosen front ball screw, just remove tip directly! What’s more, TS101 and TS100 use the same soldering iron tips.
Dual-use Anti-slip Cap
Dual-use anti-slip cap, can not only be used as a simple stand to support the iron and prevent it from rolling, but also be used for finger anti-slipping and removing the soldering tip.
Dual Power Input
Use DC and PD dual power input. The power range of the popular DC5525 interface has been extended to DC 9-24V (up to 65W). A USB-C interface replaces the original Micro USB interface, which serves for firmware upgrade, and a standard PD power input up to 45W.
Wider Temperature Adjustment Range
The temperature adjustment range has also been optimized to 50-400℃ for more application scenarios and needs.
Screen Pixel Upgrade
Compared to the previous generation, TS101 adopted a larger 128*32 pixel OLED screen to display more heating data.
“Boost” Heating Function
Newly added “Boost” heating function can quickly heat up in a short time to meet the soldering needs of special scenes.
GMT+8, 2026-11-6 00:59 , Processed in 0.155559 second(s), 23 queries .
