查看: 6537|回复: 1
[疑难问题] Adding new MDP-P906 to my working MDP-P905+MDP-M01 setup suddenly slow/restarts
发表于 2022-8-7 04:31:27 | 显示全部楼层 |阅读模式
Today I recieved the new MDP-P906 and I added it to my excitsting MDP-P905+MDP-M01.
But after adding/matching the P906 into the M01 it suddenly started to keep restarting itself.
After powering the M01 off and back on it did start up, but is now really (unworkable) slow. It is also not showing any graph for the P906. And if I go into the "configuration" screen it shutsdown again and then gets stuck into a restarting loop again.
If I turn off (disconnect power) from the P906 everything on the M01 suddenly is working again and everything responds fast again as it did in the past.
If I turn the P905 off, and turn on the P906 only, it does not go into restart loops, but it is really slow and does still not seem to read a lot of data from the P906 into the M01. I still can't see an graph line for example.
I made and video showing:
- Running only P905+M01
- Running with P906
- Deleting and running the matching process again.
https://youtu.be/EkXf8V8Fr1A
Info: Firmware
M01 = 1.25.074
P905 = 1.25.1090
P906 = 1.32.120
发表于 2022-8-8 09:56:04 | 显示全部楼层
Please upgrade M01 firmware to 1.32, we fix this bug.
https://www.minidso.com/forum.php?mod=viewthread&tid=3696
MDP-M01 & MDP-P906 APP V1.32:
- Solve the bug of M01 screen stuck;
- Improve the compatibility of P906 with the power supply head with PD protocol;
-Make the display of output voltage and current value more stable.
GMT+8, 2026-11-6 00:59 , Processed in 0.150367 second(s), 21 queries .
