查看: 3689|回复: 1
[Firmware update] follow-up on 'some additional suggestions'
发表于 2022-7-16 04:07:49 | 显示全部楼层 |阅读模式
Thank you for the fast answer!
Sounds promising!
Some additional thoughts about the already mentioned topics:
4. I'm not sure if anyone ever uses the 'L' setting as it's very inconvenient to have to turn the screwdriver as far to get full speed while having to hold the button down.
    So my suggestion is to replace the current 'L-values' with slightly decreased 'M-values' and replace the current 'M-values' with the old 'H-values', with even higher resolution  (if possible), but absolutely with the same rotation angle!
5. I did not suggest to press two buttons, but to rather perform a combination of holding the 'Set-key' down and shaking the screwdriver, to achieve the toggle action.
Thank you very much for taking the suggestions into consideration!
kind regards
发表于 2022-7-18 09:16:05 | 显示全部楼层
Thanks for your opinion, we will test it,
If this change is appropriate, it will be improved in subsequent firmware.
GMT+8, 2026-10-2 21:42 , Processed in 0.157811 second(s), 21 queries .
