查看: 3236|回复: 1
[意见建议] ES 15 suggestions
发表于 2022-6-11 21:24:04 | 显示全部楼层 |阅读模式
Operation of the screwdriver without holding down the button all the time.
Description: Pressing only once (or twice) for confirming that I want to screw / unscrew, then the action will be carried out by rotating the hand. Once the action is completed, for a new screwing / unscrewing action it will be necessary to press the start button again.
Note: If we, for example, do not turn the screwdriver after 5 seconds after pressing the start button, it will be necessary to press the start button again to prevent accidental rotation.
发表于 2022-6-13 09:16:15 | 显示全部楼层
We will test, thanks for your suggestion.
GMT+8, 2026-11-6 00:54 , Processed in 0.148449 second(s), 21 queries .
