查看: 4106|回复: 1
TS80 Low Voltage issue
发表于 2022-4-21 16:40:05 | 显示全部楼层 |阅读模式
Hey. I am having famous Low Voltage issue for TS80. I cannot get my soldering iron to work no matter what.
When I try to start heating the tip, I get Low voltage error immediately. The Power supply I use:
https://ibb.co/cLmQnHf
I have tried:
1. Updated FW version to 1.07 but didint make any difference.
2. Tried multiple USB C cables but didint make any difference.
Are there any other debugging methods to try before I return this iron?
发表于 2022-4-22 10:45:57 | 显示全部楼层
Hi, please send the email to service@morningtools.com with the problem video, we will help you, thank you.
GMT+8, 2026-11-6 00:56 , Processed in 0.165694 second(s), 20 queries .
